×We started to receive the below error in Stash. It appears to only be visible when your go to a Stash repository > settings > pull requests. You get a http 500 page. but the log files shows the below. Only change to the STASH environement is the install of add-on 'build status for automerge'. Which has since been unistalled. I've even restarted the STASH instance.
Help!
2014-01-23 13:50:57,429 ERROR [http-bio-7990-exec-4661] schuchj 830x358373x0 by1orb xxx.xx.x.xxx "GET /projects/TRAIN/repos/testrepository/settings/pull-requests HTTP/1.1" c.a.s.i.w.HandlerExceptionResolverImpl There was a SQL exception thrown by the Active Objects library:
Database:
- name:PostgreSQL
- version:8.4.17
- minor version:4
- major version:8
Driver:
- name:PostgreSQL Native Driver
- version:PostgreSQL 9.0 JDBC4 (build 801)
org.postgresql.util.PSQLException: ERROR: column "id" does not exist
Position: 73
com.atlassian.activeobjects.internal.ActiveObjectsSqlException: There was a SQL exception thrown by the Active Objects library:
Database:
- name:PostgreSQL
- version:8.4.17
- minor version:4
- major version:8
Driver:
Position: 73
at com.atlassian.activeobjects.internal.EntityManagedActiveObjects.find(EntityManagedActiveObjects.java:179) ~[na:na]
at com.atlassian.activeobjects.osgi.DelegatingActiveObjects.find(DelegatingActiveObjects.java:93) ~[na:na]
at com.sun.proxy.$Proxy1534.find(Unknown Source) ~[na:na]
at com.bolyuba.stash.plugin.AutomergeServiceImpl.getStorage(AutomergeServiceImpl.java:152) ~[na:na]
at com.bolyuba.stash.plugin.AutomergeServiceImpl.shouldCheckMerge(AutomergeServiceImpl.java:135) ~[na:na]
at com.bolyuba.stash.plugin.config.ui.CheckBuildStatusConfig.doView(CheckBuildStatusConfig.java:37) ~[na:na]
at com.atlassian.stash.internal.plugin.PluginFormFragmentsFactoryImpl$PluginFormFragmentsImpl.getViewHtml(PluginFormFragmentsFactoryImpl.java:93) ~[stash-service-impl-2.9.4.jar:na]
at com.atlassian.stash.internal.web.admin.RepositoryAdminController.getPullRequestSettings(RepositoryAdminController.java:252) ~[RepositoryAdminController.class:na]
at com.atlassian.applinks.core.rest.context.ContextFilter.doFilter(ContextFilter.java:25) [applinks-plugin-4.0.5_1384226522000.jar:na]
at com.atlassian.stash.internal.spring.security.StashAuthenticationFilter.doFilter(StashAuthenticationFilter.java:87) [StashAuthenticationFilter.class:na]
at com.atlassian.stash.internal.web.auth.BeforeLoginPluginAuthenticationFilter.doInsideSpringSecurityChain(BeforeLoginPluginAuthenticationFilter.java:111) [BeforeLoginPluginAuthenticationFilter.class:na]
at com.atlassian.stash.internal.web.auth.BeforeLoginPluginAuthenticationFilter.doFilter(BeforeLoginPluginAuthenticationFilter.java:77) [BeforeLoginPluginAuthenticationFilter.class:na]
at com.atlassian.security.auth.trustedapps.filter.TrustedApplicationsFilter.doFilter(TrustedApplicationsFilter.java:100) [atlassian-trusted-apps-core-3.0.2.jar:na]
at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:61) [atlassian-oauth-service-provider-plugin-1.9.0-m3_1383994322000.jar:na]
at com.atlassian.stash.internal.web.auth.BeforeLoginPluginAuthenticationFilter.doBeforeBeforeLoginFilters(BeforeLoginPluginAuthenticationFilter.java:89) [BeforeLoginPluginAuthenticationFilter.class:na]
at com.atlassian.stash.internal.web.auth.BeforeLoginPluginAuthenticationFilter.doFilter(BeforeLoginPluginAuthenticationFilter.java:75) [BeforeLoginPluginAuthenticationFilter.class:na]
at com.atlassian.stash.internal.request.DefaultRequestManager.doAsRequest(DefaultRequestManager.java:72) [stash-service-impl-2.9.4.jar:na]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) [na:1.7.0_21]
at java.lang.Thread.run(Thread.java:722) [na:1.7.0_21]
... 212 frames trimmed
Caused by: org.postgresql.util.PSQLException: ERROR: column "id" does not exist
Position: 73
at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2102) ~[postgresql-9.1-901.jdbc4.jar:na]
at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:1835) ~[postgresql-9.1-901.jdbc4.jar:na]
at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:257) ~[postgresql-9.1-901.jdbc4.jar:na]
at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:500) ~[postgresql-9.1-901.jdbc4.jar:na]
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeWithFlags(AbstractJdbc2Statement.java:388) ~[postgresql-9.1-901.jdbc4.jar:na]
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeQuery(AbstractJdbc2Statement.java:273) ~[postgresql-9.1-901.jdbc4.jar:na]
at com.jolbox.bonecp.PreparedStatementHandle.executeQuery(PreparedStatementHandle.java:172) ~[bonecp-0.7.1.RELEASE.jar:0.7.1.RELEASE]
at net.java.ao.EntityManager.find(EntityManager.java:788) ~[na:na]
at net.java.ao.EntityManager.find(EntityManager.java:703) ~[na:na]
at com.atlassian.activeobjects.internal.EntityManagedActiveObjects.find(EntityManagedActiveObjects.java:175) ~[na:na]
... 21 common frames omitted
The Uninstall of plugin did not work cleanly the first time. Redid uninstall of the build status plugin and all is working as expected.
Hi Jennifer,
Hmm, ActiveObjects doesn't look like it's migrating the Automerge plugin's tables correctly. From the stacktrace I can see that com.bolyuba.stash.plugin.AutomergeServiceImpl is still being called, which shouldn't happen if you've removed the plugin. Are there different errors in your logs from more recently?
While we can't do much to fix/support the plugin, please feel free to raise a support ticket with your logs attached if the pull request screen still isn't showing up.
Charles
The issue is migrating to merging pull requests. It's throwing a UI error but if you refresh the merge actually does happen. It's that same plugin. seems the uninstall didn't work. Is it safe to remove the jar from the plugins directory??
latest stack:
2014-01-24 11:05:12,652 WARN [AtlassianEvent::pool-2-thread-1] henninp 664x11300x0 11t2vol xxx.xx.x.xx "POST /rest/api/latest/projects/NXID/repos/next-gen-id-client/pull-requests/115/reopen HTTP/1.1" c.a.s.i.p.DefaultMergeRequestCheckService Merge request check com.bolyuba.stash.plugin.stash-build-status-plugin:blockPullRequestMergeCheck of type com.bolyuba.stash.plugin.WasAutomergeBuilt failed.
Database:
- name:PostgreSQL
- version:8.4.17
- minor version:4
- major version:8
Driver:
