Ho to push in read only mode?
jose camal May 25, 2018
Hi, I am using BFG Repo-Cleaner to reduce the size of the repository, However, when executing the command "$ git push" it shows
remote: Resolving deltas: 100% (638/638), done.
remote: repository is in read only mode (over 2 GB size limit).
remote:
remote: Learn how to reduce your repository size: https://confluence.atlassian.com/x/xgMvEw.
! [remote rejected] Libros-MX -> Libros-MX (pre-receive hook declined)
! [remote rejected] master -> master (pre-receive hook declined)
error: failed to push some refs
jyo
June 5, 2018
Please contact https://support.atlassian.com/contact/ for tickets such as this. If you're trying to add a commit while pushing this won't work. The basic idea is you'll have to reset to a previous commit (before going over the 2GB limit) and work from there before using BFG via:
https://confluence.atlassian.com/bitbucket/reduce-repository-size-321848262.html
jose camal June 5, 2018
Hi, I'm still waiting for your help.
jredmond
June 5, 2018
You need to contact Bitbucket Support.
Manju
May 25, 2018
Few questions,
1. What version of Sourcetree and on what OS are you using it?
2. What is the remote host to which you are trying to push? Is it Bitbucket?
3. Are you seeing this error on command line or Sourcetree?
I'm using command line on MAC OS X.
The remote host is Bitbucket.
The error is seeing in command line.
I follow the instructions on the pagehttps://rtyley.github.io/bfg-repo-cleaner/
atlassian, bitbucket, ci/cd workflows, scale ci cd, bitbucket webinar, devops pipeline, continuous integration, continuous delivery, atlassian learning, software automation, developer tools, build and deploy, pipeline optimization, atlassian community
Scale CI/CD workflows faster with Bitbucket Pipelines 🪣
Join this webinar on June 25/26th to learn how to build secure CI/CD workflows using Bitbucket Pipelines and get tips from our own engineers on how to speed up builds and operate at scale.
Register today
