How can I create a pull request task without creating a comment first?
Shane Almeida
September 8, 2016
Because of how pull request comments work, we create a lot of tasks to keep track of our pull request comments. Is it possible to create a task without first creating a comment?  It'd be nice if you could.  If not, it would be nice if there was a single button you could click or a keyboard shortcut to auto-create a task based on the comment.  Retyping the comment as the task description or selecting the comment prior to creating the task is an unnecessary extra step in a lot of cases.
3 votes
David Grani
April 17, 2018
If you highlight the comment and then click "Create Task" the task will be auto populated with your selection, which sounds like about what you want.
Marcin
September 11, 2016
Currently tasks are tied to a comment, and there's no way to create a task without it being attached to a comment. This isn't just a UI restriction, the data model for tasks currently requires a task to have a comment.
There is an existing open feature suggestion for allowing creation of a task without a comment (https://jira.atlassian.com/browse/BSERV-5233) however at this stage as far as I am aware adding this feature is not on our roadmap.
Your best bet is to vote on and watch that issue to indicate your interest, and be notified if this feature is implemented in future.
Marcin
Developer, Bitbucket Server
Alan Morey
May 21, 2020
While not ideal, another workaround for not being able to add tasks without a comment, is to just add a generic comment e.g"Tasks" and under that comment add as many tasks as you like, without having to also add comments for each task.
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
