How can i test stash functionalities
somanath kondeti February 7, 2018
How can i test stash functionalities on stash dev. How can i find all possible functionalities on atlassian stash application. Can anyone provide me the solution.
Ana Retamal
February 8, 2018
Hi Somanath! Stash was deprecated long ago, it's now called Bitbucket Server. You can install a trial version of Bitbucket Server and test all the functionalities you like there. You can download a free 30 day trial at Bitbucket download. To learn more about Bitbucket Server, you can read our Bitbucket Server documentation.
Let us know if you have any specific questions!
Best regards,
Ana
somanath kondeti February 8, 2018
Hi Ana,
 Earlier, we are using stash 3.6.1. Recently we are upgraded from stash 3.6.1 to bitbucket 4.14.12. Can you tell me the how can i test bitbucket fuctionalities on bitbucket 4.14.12
Best regards,
somanath
Ana Retamal
February 9, 2018
Hi Somanath, I'm not sure what you mean. If you want to see what Bitbucket server is capable of, my recommendation would be to get a free trial, put some data on it and play around with the features. You can get your free trial version from Bitbucket download. If you're wondering about a specific functionality, you can search our documentation or let us know what you're looking for and we'll tell you if it's available.
Hope this helps!
Ana
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
