I tried to setup in my local system for bitbucket like jira. But I did not find anything related to bitbucket. Can anyone help on the same.
Hello @d.b.kumar.chauhan
You can refer to this link: https://bitbucket.org/product/download-journey . As I see that you have added the data center tags, this link is perfect for you. I also believe that you are using your own environment, since there is an option to choose your own infrastructure.
Hi @Nikola Perisic ,
Thanks for this. But when I downloaded the atlassian-bitbucket-8.19.0 there is Linux operator file. But I want to install this in my windows laptop. So can you please help me how can we configure the same for windows.
From the options, try downloading the ZIP archive. If this is not working, download virtual box and install ubuntu on it, then download bitbucket for linux.
