Platform.sh was my first introduction to CI. I love that per branch I can assign environment variables so that with each push the branch deployment responds to its respective environment values.
I am now moving away from Platform.sh and trying to set up my own CI. Of course, I do not want every branch to be deployed using production variables and at the same time, I do not want to create variables named {BRANCH}_SSH_USER. I'd much prefer to have one variable called SSH_USER and have each branches value be different so that my deployment script does not have to be hardcoded to MASTER_SSH_USER or STAGING_SSH_USER.
Am I approaching this the wrong way? If so, how should I be?
Hi Tyler I faced a similar situation and ended up doing some workaround, see if it works for you. I created a json environment variable named SSH_USER with value:
{ "SSH":{"development": { "user": "devuservalue"}, "staging": {"user": "staginguservalue"}}}
This value was set with Secured attribute set; then I user jq to read the value according to the current branch.
sshuser=$(echo $SSH_USER | jq -r ".SSH.${BITBUCKET_BRANCH}.user")
and that did the trick for me, I have a single env variable for any branch, and can be read in a "contextual" manner with the current branch value.
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
