I'm currently trying to run my pipeline and my test into different machines using cypress. However, I don't see the documentation to learn how to send the test into multiple machines. Does anyone know how to do it?
@Alan Andres Haro Can you please explain a bit more about your use case? We are currently working on Bitbucket Pipelines Runners, please join the EAP if you would like to try it out.
My test is running in parallel, but I need some assistance to know how to run the same test into multiple nodes or machines instead of using the same node or machine. I would like to apply parallelism into my project like cypress is mentioned here https://docs.cypress.io/guides/guides/parallelization#Splitting-up-your-test-suite
The idea is to save more time on my test, I'm looking to reduce 11 building minutes into 5 minutes. However, Bitbucket does not have this function itself as other CI pipeline providers.
Do you know if it is any other way to do this inside of Bitbucket @Justin Thomas
Have you considered splitting the tests into groups and then execute them in parallel using the parallel steps?
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨Online forums and learning are now in one easy-to-use experience.
