Sign up Log in
How do I use Bitbucket Pipelines for a gradle build?
sbirgisson
July 3, 2016
I am using gradle, what do I need to do?
4 votes
xtjhin
March 27, 2017
Add the Gradle Wrapper to your repository
Our recommended approach (and Gradle's) to building Gradle projects is to commit the Gradle Wrapper to your repository.
The Gradle wrapper ensures two things:
  • the build environment doesn't need to have Gradle manually installed
  • your project will always be built with the same Gradle version
We recommend making the wrapper script executable before committing it to your repository. In Unix/Mac:
chmod +x gradlew
Then you can build your Gradle project with the wrapper:
image: java:8
pipelines:
  default:
    - step:
        script:
          - bash ./gradlew build
nasibulloh April 9, 2020
It did not work, I got ./gradlew  is not found error. I am using Java 11. Should I configure Gradle for each steps?
4 votes
xtjhin
July 10, 2016
If you have a the Gradle Wrapper committed to your repository, it's as easy as:
image: java:8
pipelines:
  default:
    - step:
        script:
          - bash ./gradlew clean build
Igor Ganapolsky July 11, 2016
Does it have to be `java:8`?  Is 7 supported?
Like Deleted user likes this
xtjhin
July 11, 2016
I believe it just needs java so you could use
image: java:7
Akos Menyhert November 4, 2016
I got bash: ./gradlew: Permission denied
Error. What should I do?
I try the following:
pipelines:
  default:
    - step:
        script: # Modify the commands below to build your repository.
          - chmod +x gradlew
          - ./gradlew assembleDebug
Unfortunately it did not works for me. I didnt have permission to change the file access.
Carey Evans
November 5, 2016
Because it's a Bash script, you can just write - bash ./gradlew assembleDebug.
Akos Menyhert November 7, 2016
It works! Thank you!
So the correct bitbucket-pipelines.yml content is:
image: java:7
pipelines:
  default:
    - step:
        script:
Kashif-Ur-Rehman December 12, 2016
@Carey Evans, I am following above tutorial, but build is failing .
Logs says that:-
 bash: ./gradlew: No such file or directory
walkerca December 16, 2016
I'm getting a build failure too.
This is from a gradle project
+ bash ./gradlew clean buildError: Could not find or load main class org.gradle.wrapper.GradleWrapperMain
I'm using this configuration
image: java:8
pipelines:
  default:
    - step:
        script:
Kashif-Ur-Rehman December 16, 2016
@Carl Walker.
You can try this one:-
image: qlik/gradle
pipelines:
  default:
    - step:
        script:
          - gradle test
          - gradle build
          - gradle war
you have to
  - cd build
because gradle create war inside that build/libs..
Thanks Kashif.  It looks like "gradle build" with the qlik/gradle image will work.  It's still failing, but on a missing JavaFX jar.  The command is successfully invoked.
@Carl Walker
You can find your war inside
build/libs folder, means after gradle war command you should run
- cd build
          - ls
          - cd libs
          - ls
SmsParser December 22, 2016
Hi, is it possible to set storePassword and keyPassword for signingConfigs?
xtjhin
March 27, 2017
Apologies all. You need to either commit the wrapper as an executable
chmod +x gradlew
or run it through bash:
image: java:8
pipelines:
  default:
    - step:
        script:
sbirgisson
July 3, 2016
Kashif-Ur-Rehman January 23, 2017
@Sigge Birgisson,
I followed your above mentioned url i,e
https://bitbucket.org/hascode/bitbucket-vertx3-pipeline/src/a2befa4ce4b15d970d9c4f7952ebf2578861f6b3/bitbucket-pipelines.yml?at=master&fileviewer=file-view-default
and here is my script:-
# This is a sample build configuration for Gradle.
# Check our guides at https://confluence.atlassian.com/x/VYk8Lw for more examples.
# Only use spaces to indent your .yml configuration.
# You can specify a custom docker image from Docker Hub as your build environment.
image: qlik/gradle
pipelines:
default:
- step:
script:
- gradle clean
- gradle test
- gradle ear
but previously it was working fine from last 2 months, but today when i start build, it fails on
gradle clean command  by saying that:-
.sh line 22 gradle command not found bibucket pipeline
Can you help me?
thanks in advance
Jie Li November 6, 2018
I have gradle wrapper running in pipeline, but every step it re-downloads the gradle files even I set
caches:
- gradle
- gradlewrapper
definitions:
caches:
#location of wrapper in my project
gradlewrapper: ~/gradle/wrapper
 After I check the pipeline log, I see that the pipeline download gradle wrapper to `.gradle/wrapper`, so why is it a different location?
Kashif-Ur-Rehman January 26, 2017
@Joshua Tjhin,
I followed follwing
image: qlik/gradle
pipelines:
default:
- step:
script:
- gradle clean
- gradle test
- gradle ear
Can you help me?
thanks in advance
