How do I use MySQL in Bitbucket Pipelines
SebC
April 12, 2017
How do I get a mysql database to run with by pipeline?
SebC
April 12, 2017 edited
You'll want to take advantage of services in bitbucket pipelines.
For the simple uses, you can create an empty database named 'pipelines' and use the 'root' user with password 'let_me_in' to connect on localhost:3306
pipelines:
  default:
    - step:
        image: node
        script:
          - npm install
          - npm test
        services:
          - mysql
definitions:
  services:
    mysql:
      image: mysql
      environment:
        MYSQL_DATABASE: pipelines
        MYSQL_ROOT_PASSWORD: let_me_in
For more complex situations, you can create a test user to help validate database permissions and other priviledged settings.
The below bitbucket-pipelines.yml will create an empty database named 'pipelines' and user 'test_user' with password 'let_me_in' to connect on localhost:3306. The root user will have a random password created for it and not be accessible.
pipelines:
  default:
    - step:
        image: node
        script:
          - npm install
          - npm test
        services:
          - mysql
definitions:
  services:
    mysql:
      image: mysql
      environment:
        MYSQL_RANDOM_ROOT_PASSWORD: 'yes'
        MYSQL_USERNAME: test_user
        MYSQL_PASSWORD: test_user_password
Daniele Piaggesi
April 17, 2017
I tried with your configuration above:
MYSQL_RANDOM_ROOT_PASSWORD: yes
but Pipeline said to me that:
The 'environment' section in your bitbucket-pipelines.yml file must be a map.
Obviously it was a map. I remove this environment and put original ones, taken from mysql docker hub page. It worked.
Probably this configuration is broken and you should update your documentation.
Like • 2 people like this
Yuriy Znatokov
April 20, 2017
Having the same problem, obviously the configuration posted above and the one in the docs are broken.
How did you manage to solve it?
caiquecssilva
April 20, 2017
I had the same issue and i changed to MYSQL_DATABASE: 'pipelines' for example
Yuriy Znatokov
April 20, 2017
Got it working with the following config:
environment:
MYSQL_ROOT_PASSWORD: root_user_password
MYSQL_USER: test_user
SebC
April 26, 2017
Thanks for the feedback! Turns out there was an issue where values like "yes" or "true" are being converted to booleans, which is causing some problems when they're loaded into the service container (yes becomes true for example).
Quoting these values will force them to be treated as strings - I'll be discussing this within the Pipelines team to try and improve the experience.
kenkinder November 1, 2018
So, this is still broken, and the documentation is still giving you examples that don't work. Is a fix coming any time?
Ulrich Jahnke
January 14, 2019
@SebCPlease change documentation https://confluence.atlassian.com/bitbucket/how-to-run-common-databases-in-bitbucket-pipelines-891130454.html to use
MYSQL_USER
in MySQL - test user section.
Dheeraj Kumar
April 1, 2019
+ mysql -u root -p root -h 127.0.0.1 < test.sql
bash: mysql: command not found
while running it i got this error
Like • Leonid Lezner likes this
maciejgut
August 13, 2019
Try to install something that provides mysql command. For example on Debian image (in my case "php:7.1.29") this installs the standard mysql client:
- apt-get update && apt-get install -y mysql-client
Jonas Lomholdt
June 22, 2017 edited
I just can't make this work. I get a `Exception: SQLSTATE[HY000] [2002] php_network_getaddresses: getaddrinfo failed: Name or service not known` no matter what I do. I have tried a regular user and root user. I also tried using the hostname `mysql`. Nothing works. Can anyone confirm that this is actually a working thing?
I also get a `mysqld: Shutdown complete` at the end of the database service log. Why?
mtumaini
October 20, 2017
Just wondering if anyone got a solution to this issue.
I am experiencing same issue with similar mysql configuration. My pipeline reports php_network_getaddresses failure.
Reece Alexander
Ensure your connecting to the DB with the hostname 127.0.0.1 and not "localhost" as the latter means nothing in docker.
AS November 6, 2020
I eventually got this working. But how can I change the mysql cnf file and then reboot the mysql server/service?
Really struggling with this bit, if anyone has any ideas?
Alfred Bez July 4, 2019
Somehow this does not work for me, here's my bitbucket-pipelines.yml:
image: debian:stretch
pipelines:
pull-requests:
- step:
script:
- mysql -h 127.0.0.1 -u root -ptest_user_password -e "SHOW DATABASES"
definitions:
services:
mysql:
image: mysql:5.7
variables:
MYSQL_ROOT_PASSWORD: 'test_user_password'
 Output:
+ mysql -h 127.0.0.1 -u root -ptest_user_password -e "SHOW DATABASES"
ERROR 2003 (HY000): Can't connect to MySQL server on '127.0.0.1' (111 "Connection refused")
I forgot to add the service to the pull-requests pipeline:
pipelines:
pull-requests:
- step:
script:
services:
- mysql
definitions:
services:
mysql:
image: mysql:5.7
variables:
Like • pcsdev likes this
Usama Habib July 31, 2019
Hi @Alfred_Bez did you experience this error after mentioning services tag in you yml file as well or was it gone? since my pipelines file is through me same error but not everytime time only sometimes i do have this *services* tag but its very unusual sometimes pipeline throws this error and sometime it passes build successfully for the same file.
Any help will be appreciated if you know anything.
Alfred Bez July 31, 2019
Hello @Usama Habib , it works now for me, I don't see the error at all.
