So I have a "lerna" monorepo. i can cached the main "node_modules" in the root directory using "caches: - node" but when i run "lerna bootstrap" to install the inner node_modules ("/packages/((some_package))/node_modules") it is not cached.
I am also encountered this. Is there any solution?
I'm also very curious about this as it would speed up my build tasks by a pretty big factor.
I've personally tried using custom cache like: https://gist.github.com/RPDeshaies/57d92a71f0a0c9d5594fdc10780fa512
But it still doesn't seem to work fully since my local environments install my dependencies in 4s while Bitbucket does it in ~50s.
Any advice on this Atlassian ?
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
