How do i get commits from all Projects ?
BIBO
August 23, 2021
I would like to get the count for commits on all all projects
Kevin Johnson
August 23, 2021
Hi @BIBO ,
You can use Awesome Graphs for Bitbucket plugin for
  • projects and repositories in your Bitbucket that a certain user-contributed to (filter by author)
  • commits that were made long ago to a repository with high activity (filter by time)
  • the commits of a user made to a repository or project (filter by author and project/repo)
  • all the commits made to a project (filter by project).
Hope this helps.
Kevin.
Anastasia Voronova
Hi there,
@Kevin Johnson thank you for mentioning our app :)
@BIBO If you need total number of commits on your instance, the easiest way to do it is to use the following query
Please, let me know if this works for you.
Anastasia
Like Kevin Johnson likes this
