I see there are predefined caches in pipelines now...that's great. We are using maven, so I'll use that as an example here.
I am, however, unclear on how they work. I could see it one of two ways.
maven-corporate: ~/.m2/repository/our/corporate/package
I've been trying to configure it assuming option #1 above, but it does not seem to work properly -- or at least the reported cache size is very small (eg <900 B), so I don't think it is working based on that.
It would be nice if the documentation of Pipelines Caching were updated with more details, about this issue and all around.
Hi Ben,
Thanks for your question.
Pre-defined caches work like you described as 2. They are just a convenient mapping of commonly cached directories so that users won't need to define them. Indeed they'll cache the entire m2 repository.
Caches are private to the repo. Could you describe your security requirements a little further?
Re: caches being <900B, looks like we have an issue where for some Docker images, caches are saved empty. The dev team are looking into.
Thanks for the feedback, I'll update our documentation to clarify this.
Thanks for the response.
Our security concerns are just born out of this line the docs:
To me, this implies that there is a security risk with the caching, but perhaps no more so than any other part of our source code and artifacts being available to pipelines, so I'm sure it's fine.
Join this webinar on June 25/26th to learn how to build secure CI/CD workflows using Bitbucket Pipelines and get tips from our own engineers on how to speed up builds and operate at scale.
