How does a regex works in Scriptrunner
Margaria Vince January 17, 2023 edited
Hello, I am currently working on a pre-hook for tags on scriptrunner that will force users to freeze there dependencies. I have a problem about that.
I did a regex that checks this situation :  .*requires\(\"[^\d|_|\-](\S)+/\[(\d)(\.\d)*\]
I did this regex using regex101.com based on a Java 8 flavor. The problem I have is that it seems that either scriptrunner does not understand this or it is that I don't know how to test my tags.
Is there someone that can help me please ?
Jeroen Poismans
Hi there,
Do you have an Adaptavist account? They have a Script library where I found this script to user regex to check mail. With some change you should be able to get this to work on your regex:
https://library.adaptavist.com/entity/use-regex-to-find-emails-address
Regads,
Jeroen
