How to Remove/Disconnect BItbucket from JIRA
Nadeem Zakir November 1, 2020 edited
deleting from Jira wont delete the repos from BitBucket correct?
Daniel Ebers
November 2, 2020
Hi Nadeem,
in case you mean by your question that you want to remove an application link and if this harms your repos in Bitbucket the answer is 'no'.
You can remove it without repos being deleted.
Daniel
