I want to update my yml file to ignore commits from certain users. Is this possible? Is there a similar solution? Ideally I wouldn't even want to trigger the build in the first place.
Pseudo code example of yml file (ignore syntax, I'm just showcasing what I'm trying to do)
user = git show -s --format='%ae' $BITBUCKET_COMMIT
unwantedUser = "person@mail.com"
pipelines:
tags:
'**' && user != unwantedUser:
- step:
script:
What would be the actual syntax to achieve that?
I ended up including the [skip ci]
string in my commit messages to avoid triggering the pipeline.
Thanks for taking a moment to answer your own question!
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨Online forums and learning are now in one easy-to-use experience.
