I want to split a huge repository into a lot of separate ones using the folders from the main repository. I know how to separate folders from the main repo an create new ones. However I have literally 100s of those. The only way to create a repo on the (standalone) bit bucket server is using the server frontend (web browser). Is there a simple way to do this from a script (git bash)? Is the REST API the only way to do that (with a plain http:// protocol, not HTTPS!)? Any tools I can use?
Hi @Jurgen Schober,
Yes, this is possible with REST API.
For example you can use this migrate_bitbucket_server_to_bitbucket_cloud
and break down into the portion you'd like to use.
I am going with this answer for now. However, it doesn't exactly answer my question - but I should be able to get everything I need from there. If anyone has more examples (especially using a local server without requiring HTTPS I would appreciate it).
