we have 20 + lambdas with 100+ end points, need to deployed with AWS SAM templates. Please suggest the best approach and please provide the sample scripts/templates if any.
Hi Igor Stoyanov, Thanks for sharing with me, but I have one query related to the same. Please find the details below.
In our architecture, we have to deploy 20 lambdas, each lambda is deployed through a separate template which is in root folder of the code and we have three different environments like Test, Staging and Production. When i tried to deploy lambda1 in 3 environments, it is working fine, but when i try to deploy lambda2 into 3 environments, getting error like environment defined multiple times. Please find the sample code and error attached here. Any help for this solution is highly appreciated. Thanks in advance.
@koti r hi. What you ask is under development: Support multi-step deployments
Also i found a question related to your problem: https://community.atlassian.com/t5/Bitbucket-questions/The-deployment-environment-test-in-your-bitbucket-pipelines-yml/qaq-p/971584
maybe you can find some useful info there.
Regards, Igor
