How to deploy artifacts from pipelines?
Deleted user July 27, 2016
I want to deploy artifacts from pipelines build. I don't want the build to do the deploy for me, but I want it to give me just the artifacts and then I'll deploy them to aws, like I have now in bamboo. Is is possible?
Tom Bradshaw
July 28, 2016
At the moment there is no way to access artifacts after the build is finished. A work around is to build and deploy within the pipelines step or to transfer your artifacts to a server to which you have access and then retrieve it from this server.
To use SFTP with pipelines please consult the guide here: https://answers.atlassian.com/questions/39429257/how-do-i-set-up-ssh-public-key-authentication-so-that-i-can-use-ssh-sftp-or-scp-from-my-bitbucket-pipelines-pipeline
Alternatively to deploy to AWS from pipelines consult the guides here:
S3: https://bitbucket.org/ian_buchanan/pipeline-example-aws-s3
CodeDeploy: https://bitbucket.org/shivaman/bb_codedeploy_helloworld
Elastic Beanstalk: https://bitbucket.org/irlrobot/bb_beanstalk_python/src
Deleted user July 30, 2016
Thanks. Is it planned?
Like • elynch303 likes this
Kashif-Ur-Rehman November 21, 2016
@Thomas Bradshaw, I created a war from pipeline, my build is successfully completed. But i cannot see War file any where.
Here are  ending logs..
Copying webapp resources [/opt/atlassian/pipelines/agent/build/EmailService/WebContent]
[INFO] Webapp assembled in [117 msecs]
[INFO] Building war: /opt/atlassian/pipelines/agent/build/EmailService/target/EmailService-1.0-SNAPSHOT.war
[INFO] ------------------------------------------------------------------------
[INFO] BUILD SUCCESS
Will you please help me that how i can get that WAR file ?
Isaac Weathers December 6, 2016
That's my question too. After I run a gradle build the build is generated in a build/libs/ directory but that is not checked in to the repo. So when I try to upload the artifact it does not see it.
Isaac Weathers December 7, 2016
Found a solution https://answers.atlassian.com/questions/users?username=557058%7Ce2a778fb-f12e-41d6-9ed4-bfa92edd319a
Run it from a bash script instead. The steps are just that... steps. So you need to run sets of executables together so they have a logical chaining order.
EX:
#!/usr/bin/env bash
./gradlew clean build --stacktrace --no-daemon
python s3_upload.py sample build/libs/sample.war build/libs/sample.war
- step:
    script: # Modify the commands below to build your repository.
      - chmod +x pipelines-runner.sh #needed to allow Pipelines to run shell scripts
      - ./pipelines-runner.sh
Kashif-Ur-Rehman December 7, 2016
@isaac weathers you can also run maven script to get war file and then transfer that file to your FTP server. i.e
you can get help from here:-
Kashif-Ur-Rehman February 21, 2017
@Thomas Bradshaw, is there any way that we can transfer our file (war file if build is successful) from pipeline to windows server instead of linux ?
Tom Bradshaw
February 21, 2017
Hi @Kashif-Ur-Rehman,
I can see you asked a similar question on https://answers.atlassian.com/questions/39429257 Steven's response to that question seems to answer the question nicely. From a pipelines perspective deploying to a windows or linux SFTP server should be exactly the same.
Tom
Yes, I saw his reply, and going through his instructions.
Kashif-Ur-Rehman March 2, 2017
@Thomas Bradshaw, what should i do for transferring artifacts (war/ear file) to windows base server from pipeline cloud ?
right now I have installed "SFTP/SSH Server on Windows using OpenSSH"
here is URL :- https://winscp.net/eng/docs/guide_windows_openssh_server#installing_sftp_ssh_server
but i am not sure how can i send artifacts from cloud to windows server ?
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
