How to deploy my maven project to heroku without Docker container
vinoth_ssv
May 12, 2020 edited
Hi All,
I have tired to deploy my jar file to heroku instance, below is my pipeline script which i used to deploy it in heroku.
but during build process, im unable deploy jar file to the heroku instead source of my git project has been deployed or uploaded to my heroku instance at /app .
can anybody help how to deploy jar file to the heroku using pipeline script .
# This is a sample build configuration for Java (Maven).
image: maven:3.6.1
clone:
depth: full
pipelines:
branches:
master:
- step:
name: Build and Deploy Snapshot Artifact
trigger: automatic
image: maven:3
caches: - maven # cache the maven
script:
mvn install clean
mvn package
step: name: Create artifact in HEROKU - Prod
deployment: production
script:
git push https://heroku:$HEROKU_API_KEY@git.heroku.com/$HEROKU_APP_NAME.git HEAD:master
- mvn clean
- mvn install
Oleksandr Kyrdan
May 26, 2020
Hi @vinoth_ssv ,
Thank you for your question!
Let's use heroku-deploy pipe in your case.
Also, we have an example of how to deploy a Java app with the heroku-deploy pipe.
MigalLewis
May 13, 2020
@vinoth_ssv  I have successfully used a pipeline to deploy to heroku using the heroku-maven-plugin
First add the plugin to your pom
<plugin>
<groupId>com.heroku.sdk</groupId>
<artifactId>heroku-maven-plugin</artifactId>
<version>3.0.2</version>
<configuration>
<appName>migal-resume</appName>
<includeTarget>false</includeTarget>
<includes>
<include>${project.build.directory}/${project.build.finalName}.jar</include>
</includes>
<jdkVersion>1.8</jdkVersion>
<processTypes>
<web>java $JAVA_OPTS -jar target/${project.build.finalName}.jar -Dserver.port=$PORT</web>
</processTypes>
</configuration>
</plugin>
then  you will need to get your heroku api key and add it to your Deployment Variables in Btbucket
and then to deploy add - HEROKU_API_KEY=$HEROKU_API_KEY mvn heroku:deploy
image: maven:3.6.1
clone:
depth: full
pipelines:
branches:
master:
- step:
trigger: automatic
image: maven:3
script:
mvn install clean
mvn package
script:
I hope this helps
