How to deploy script files to staging with runner
Ruby February 1, 2024
Hi I would like to deploy new files to staging server automatically using a bitbucket pipeline. There won't be build or anything. So, I set up self-hosted runner on a staging server. I merged a code then the pipe line run and it said successful, but I couldn't see the changes in my staging server. May I know why and what steps am I missing?
Mark C
February 4, 2024
Hi @Ruby,
Thank you for reaching out to the community.
May I know how you're currently deploying new files to the staging server?
Are you using Rsync, FTP/SFTP or just Git operation (i.e. you're cloning/fetching your repository for new changes in the staging server)?
Mark C
Ruby February 5, 2024
Hi @Mark C, it will be git and power shell script.
Mark C
February 6, 2024
Hi @Ruby,
Are you doing Git pull in an existing repository or you're cloning the repository to get new updates for the staging environment?
Mark C
Ruby February 28, 2024
Hi @Mark C I am using powershell script as it is hosted in windows. I use branches and it builds but build log doesn't show all. Where can I see all the build logs?
Mark C
February 28, 2024
Hi @Ruby,
You can check your Windows self-hosted runners logs usually from the location below:
<runner_working_directory>\<runnerUuid>\runner.log
You can also check this page for more information about troubleshooting runners. - https://confluence.atlassian.com/bbkb/troubleshooting-runners-1167819666.html
Mark C
Like • Sabine Mayer likes this
