Hello, I have a few paid and free add-ons running in my Bitbucket 5.x instance, and I was wondering if there is an easy way to tell how much use they are getting, for future purchasing decisions etc.
I found the solution. It's related more to hooks rather than addons. In my case it works because each addon has a hook. So first need to connect to Bitbucket's db. Then run next query
SELECT
name
AS
repo_name,
hook_key,
lob_data
AS
settings
FROM
bitbucket.sta_repo_hook
INNER
JOIN
bitbucket.repository
ON
sta_repo_hook.repository_id = repository.id
INNER
JOIN
bitbucket.sta_shared_lob
ON
sta_repo_hook.lob_id = sta_shared_lob.id
WHERE
hook_key
LIKE
'%hook_key_form_atlassian_plugin_xml%'
AND
is_enabled =
'1'
It returns all enabled plugins with json settings for each of them.
sta_repo_hook - table with many-to-many relationship between repos and hooks
repository - table with repos
sta_shared_lob - settings for plugins
It is not an easy thing because the plugin usage is not monitored or logged.
Probably you can enable the access logs and hope that every single call is recorded in there. But it depends on the implementation of the plugin. For example, there might be hooks, pull requests restrictions etc that are not logged even in the access logs.
I have the same question. Our use case is that we have a really big amount of repos. And a few amount of 'probably' not used plugins. And need to determine whether plugins are used or not. It it possible to check?
