How to explore projects on bitbucket.org
stantonxu
July 12, 2018
When I go to http://bitbucket.org/repo/all, I cannot see any projects listed there.
How can I explore the projects on BitBucket? Is it related to the plan I have?
Norbert Csupka
July 13, 2018 edited
Dear Stanton Xu,
Thank you for opening this thread on our Community Support. Under the https://bitbucket.org/repo/all website, you can search amongst repositories on Bitbucket, where the repositories are set as Public. As long as you don't provide a text to search for, it's not going to list any repository.
If you log in to bitbucket.org with your user credentials and on the left side, you click on "Repositories", it's going to list all the repositories, which you created or someone else has shared it with you.
Please let me know if I answered your question.
Best Regards,
Norbert
Atlassian Bitbucket Cloud Support
stantonxu
July 13, 2018
Norbert, thanks for your quick response.
So you mean BitBucket doesn't provide a function to explore all the projects on it, if it is not shared?
