How can I permanently make the pull count refer to changesets for the current branch only? I.e., the number of changesets displayed in the toolbar as an overlay to the pull icon should refer to the remote commits on the current branch only.
I know that I can enter a branch name in the "Advanced" section of the pull dialog, but that
1) does not affect the pull count in the toolbar,
2) is not permanent (i.e. I would have to choose the branch on the next pull again),
3) does not work for me anyway (i.e. the number of changes displayed in "Incoming changes" does not change when choosing a branch without any remote changes or not).
At the moment you can't configure this, for Mercurial the incoming changesets always refer to the entire repository. If you like you can raise feature requests & track them at https://jira.atlassian.com
About the pull dialog, selecting a branch to pull from doesn't re-query the incoming list but it does only pull that branch when you click OK.
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
