How to migrate Bitbucket to AWS
tomisaacson October 31, 2018
I'm incredibly frustrated. I've been trying to migrate our Bitbucket server from a local VM to AWS and I can't get it to work. I started with https://confluence.atlassian.com/bitbucketserver/administering-bitbucket-server-in-aws-776640308.html then used the server template from https://confluence.atlassian.com/bitbucketserver/quick-start-with-bitbucket-server-and-aws-776640254.html. We backed up our existing server using Bitbucket Server Backup Client so I went to https://confluence.atlassian.com/bitbucketserver/using-the-bitbucket-server-backup-client-776640064.html#UsingtheBitbucketServerBackupClient-runrestore.
But here's where I started to have trouble. The server seemed to have a demo project in /var/atlassian/application-data/bitbucket but the additional storage (200GB) appeared under /media/atl/bitbucket/:
$ df -hl
Filesystem Size Used Avail Use% Mounted on
devtmpfs 1.9G 80K 1.9G 1% /dev
tmpfs 1.9G 0 1.9G 0% /dev/shm
/dev/xvda1 50G 43G 6.9G 87% /
/dev/xvdb 15G 39M 15G 1% /media/ephemeral0
tank/atlassian-home 193G 66M 193G 1% /media/atl
tank 193G 0 193G 0% /tank
I stopped the server:
sudo -u atlbitbucket /opt/atlassian/bitbucket/bin/stop-bitbucket.sh
then tried using:
sudo -u atlbitbucket /opt/atlassian/bitbucket/bin/set-bitbucket-home.sh /media/atl/bitbucket
I couldn't figure out the parameters for the restore. After some guesswork I took the username and password from /var/atlassian/application-data/bitbucket/shared/bitbucket.properties, then guessed at the database host and port:
sudo java -Djdbc.override=true -Djdbc.driver=org.postgresql.Driver -Djdbc.url=jdbc:postgresql://localhost/bitbucket -Djdbc.user=atlbitbucket -Djdbc.password=#### -Dbitbucket.home=/media/atl/bitbucket/ -jar bitbucket-restore-client.jar bitbucket-20181024-233703-804.tar
But then I got "The target database contains tables whose names collide with Bitbucket's tables. Please migrate to a clean, empty database."
So I used:
sudo -u atlbitbucket psql -d bitbucket -U atlbitbucket
then this code to clear the database https://stackoverflow.com/a/36023359/264822
I finally got the restore to work and I reran the server  but now when I open the URL it redirects to http://127.0.0.1:7990/setup. It's likely that one of my previous steps has screwed something up but I have no idea because of the complete lack of documentation around this.
Does anyone have any experience with this? Once I get the damned thing working I'm going to write up a blog post so nobody else has to go through this stupidity.
Emily Chan
January 13, 2020
Hi @tomisaacson and Community!
We've just built the beta of a solution to help ease migrations from Server/Data-Center-on-prem to Data-Center-on-AWS-Quickstarts.
Would you be interested to join our beta program and try out this solution? If you're interested, or would like to find out more, please email me at echan@atlassian.com.
John Lawlor
November 1, 2018
That looks like Bitbucket can't talk to the database, so it's starting up as if it was a fresh install.
Can you check your database connection settings in your bitbucket.properties?
Also check /var/atlassian/application-data/bitbucket/log/atlassian-bitbucket.log to see if there are any connection errors shown there.
tomisaacson November 1, 2018
/media/atl/bitbucket/shared/bitbucket.properties:
jdbc.url=jdbc\:postgresql\://localhost/bitbucket
I can't see anything that looks like an error in the log, but not sure what I'm looking for.
John Lawlor
November 2, 2018
# primary db url
jdbc.url=jdbc:postgresql://localhost:5432/bitbucket
Maybe try and add the port number as above..
Also, I see that you are using a non-standard install location, as in /media instead of /var. That complicates things slightly. Make sure the shell scipts in /opt/atlassian/bitbucket/5.15.0/bin/ are using the /media path rather than /var.
tomisaacson November 2, 2018
How do I know what the port number is? That's part of my problem, none of this is documented in the setup instructions.
I'm using a non-standard install location because I need more storage in my VM and that's where AWS adds it. How else should I be doing this?
John Lawlor
November 5, 2018
The default port is 5432 for postgres. You can confirm that postgres is running on that port with:
netstat -anp | grep 5432
Let's make that change first and go from there.
