How to pass a base64 encoded variable to the SFTP Deploy Pipeline
raschidjfr
I'm trying to follow the guide to manage multiple repository ssh keys . I've added my ssh as a secure variable, encoded in base64. But how do I decode it to pass it into the pipe's variables (parameters)?
script:
  - pipe: atlassian/sftp-deploy:0.4.1
    variables:
      SSH_KEY: $MY_SSH_KEY_B64  //<- How do I decode it before passing it??
raschidjfr
Ok, just for the record, I managed to solve my problem. I don't know exactly what the problem was, but it all worked when I encoded the key using this online tool rather than using `base64 -w 0 < my_ssh_key`.
Oleksandr Kyrdan
August 25, 2019 edited
Hi @raschidjfr ,
you should only provide encoded SSH_KEY as a variable and pipe will decode it to the ~/.ssh/pipelines_id automatically.
Alex
raschidjfr
Thanks for your answer @Oleksandr Kyrdan . Sorry, I didn't fully get  you... should I pass it encoded or decoded? I tried saving it encoded as the tutorial states but then I'm getting "invalid format" error:
Load key "/root/.ssh/pipelines_id": invalid format
✖ Deployment failed.
Maybe there's something wrong with the key format but I've been using it without problem from my terminal. You know, my key file looks something like this:
-----BEGIN RSA PRIVATE KEY-----  // line break here
MIIEpAIBAAKCAQEA1fgwkzccOpKpb4Ln6wIaCVFWgnRX+vANU/s5E3K8boCYQ8FU // line break here
XVrfupIjyPudSgs1RJvMp13PPkLfq+O92bWHQaAkm0b4+xKts8BHsGt8S7FgQjTe // line break here
Z57q0odcy76rGBq2iiqH2YU9P4sDdqLj/r1ZRl+FURwhHk9ATaFx+w== // line break here
-----END RSA PRIVATE KEY----- // line break here
// There's a last line break here
So I encoded it with base64 -w 0 < my_ssh_key:
LS0tLS1CRUdJTiBSU0EgUFJJVkFURSBLRVktLS0tLQ0KTUlJRXBB(...)klWQVRFIEtFWS0tLS0tDQo=
And then the I get the "invalid format" error when running the pipline. Any thoughts?
Like • Abhishek Kumar likes this
Oleksandr Kyrdan
August 28, 2019
Hi @raschidjfr ,
yep, encoded SSH_KEY as a variable according to the readme
# LINUX
$ base64 -w 0 < my_ssh_key
All your steps look good.
Try to check twice start and end of the encoded key before copying it, to prevent copying additional symbols.
Like • raschidjfr likes this
