How to restructure documentation that has versions?
Jeyan J
August 5, 2015
Greetings,
I'm new to SourceTree, thus wondering what would be the best way to perform the following. Below is my scenario:
I need to revamp (restructure) a repository that consist of the main documentation with versioning ( 2.0, 2.1, 2.2, 3.0, 3.1 ). I'm currently editing the 3.2 version, some files need to be removed and screenshots replaced ( due to minor UI changes ). However, some of the removed files would need to be in the future release 4.0.
I'm unsure about the configuration, but the auto merge function seems to be causing the errors when making the
changes. Currently, each version is a release branch, though some versions are based branches i think.
Thanks in advance for the help
Balázs Szakmáry
August 5, 2015
Read this. Afterwards you will better understand how to work with the auto-merging workflow.
atlassian, bitbucket, ci/cd workflows, scale ci cd, bitbucket webinar, devops pipeline, continuous integration, continuous delivery, atlassian learning, software automation, developer tools, build and deploy, pipeline optimization, atlassian community
Scale CI/CD workflows faster with Bitbucket Pipelines 🪣
Join this webinar on June 25/26th to learn how to build secure CI/CD workflows using Bitbucket Pipelines and get tips from our own engineers on how to speed up builds and operate at scale.
Register today
