How to run selenide tests in bitbucket-pipelines (selenoid)
Vitali Konachyk March 18, 2022
It is necessary to run tests on selenide in selenoid on bitbucket-pipelines, I did everything locally, and it works, but now it is unclear how to implement it in bitbucket. I have no experience writing bitbucket-pipelines.yml
Locally I :
1. Installed docker
2.Launched docker
3. Downloaded the start file (https://github.com/aerokube/cm/releases/tag/1.8.1 ) 4.Launched it with the command '$ ./cm selenoid start --vnc' and '$ ./cm selenoid-launching the user
interface'
5. Launched the tests with the command 'mvn test'
Norbert Csupka
March 21, 2022 edited
Hi @Vitali Konachyk
Thank you for contacting Atlassian Community, my name is Norbert and I'm a Bitbucket Cloud Support Engineer, it's nice to meet with you! Welcome to the Atlassian Community!
I would like to inform you that Bitbucket Pipelines is a service, which basically runs a Docker image and within the Docker image, it runs commands.
For the basics, how you can get started with Bitbucket Pipelines, I would like to suggest you to read through these set of documentation: https://support.atlassian.com/bitbucket-cloud/docs/get-started-with-bitbucket-pipelines/
Let me give you a template:
image: docker_image_that_you_used_locally
pipelines:
default:
- step:
services:
- docker
script:
- wget https://github.com/aerokube/cm/releases/tag/1.8.1
- ./cm selenoid start --vnc
- mvn test
definitions:
services:
docker:
memory: 512
Please let me know how it goes, we're here to help.
Best Regards,
Norbert
Atlassian Bitbucket Cloud Support
Vitali Konachyk March 21, 2022
Hi!
I supplemented the script, but it didn't help. Not enough accesses(image (2).png image (3).png
Norbert Csupka
March 22, 2022
Hi @Vitali Konachyk
Thank you for the picture, there was no Docker service initiated, that's why you had this problem.
I edited yesterday's comment with a docker service.
Can you try that and let me know if it works for you?
Best Regards,
Norbert
Like Vitali Konachyk likes this
Vitali Konachyk March 22, 2022
Hi! I have updated the dock, but a new problem has appeared
"x Failed to start: failed to create container: Error response from daemon: authorization denied by plugin pipelines: -v only supports $BITBUCKET_CLONE_DIR and its subdirectories"
Theodora Boudale
March 23, 2022
Hi @Vitali Konachyk,
Please allow me to step in as Norbert is out of office.
Based on the error message, it looks that the command you are running may be trying to create a Docker container and mount volumes outside $BITBUCKET_CLONE_DIR ($BITBUCKET_CLONE_DIR is the path where your repo is cloned in the Docker container that runs your build).
If so, this is something that is not supported in Pipelines, see below the section "Full list of restricted commands":
I would suggest reaching out to the developers of selenoid (you can create an issue here: https://github.com/aerokube/selenoid/issues), ask what directory is being mounted, and if it is possible to change that e.g. with a configuration file in your repo.
Theodora
