Is there a way to setup bitbucket so that it will automatically detect an uncompilable code being pushed and one can't raise a PR?
You could create a bitbucket pipeline and configure it to build your code.
You can then configure your branch PR (in settings>workflow>branch strategies) to merge only if the build passes.
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨Online forums and learning are now in one easy-to-use experience.
