How to trigger a pipeline with a build hook?
Oliver Pal
October 29, 2019
we have a Gatsby Frontend which needs to be build once the Drupal Backend ist updated with content.
Everything works fine with the standard git workflow triggering pipelines.
Is there any similar feature like build hooks from netflify?
https://docs.netlify.com/configure-builds/build-hooks/#parameters
I want to trigger the pipeline once a day with cron.
freesko
June 25, 2020
It seems the Piplines doesn't support build hooks in the same way Netlify does, In fact with Pipeline you need to be authenticated to be able to trigger a build hook to build your statically build website with CMS (Gatsby + Prismic + Netlify in my case) and that is not compatible with my CMS and platforms
Philip Hodder
January 16, 2020
Hello Oliver,
You can trigger a pipeline via the REST API here: https://developer.atlassian.com/bitbucket/api/2/reference/resource/repositories/%7Bworkspace%7D/%7Brepo_slug%7D/pipelines/
You can also configure scheduled pipelines in the UI directly, if you prefer: https://confluence.atlassian.com/bitbucket/scheduled-pipelines-933078702.html
Phil
atlassian, compass, developer experience, devex, platform engineering, internal developer platform, component catalog, atlassian learning, productivity tools, developer productivity, software architecture, compass webinar, engineering teams
Discover how Compass drives DevEx and productivity at Atlassian 🏃🏻‍♂️
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨
