How to use Docker with Self-hosted Linux Shell runner?
Ievgen Koshevyi
October 31, 2022
When i'm trying to start this pipeline
pipelines:
branches:
master:
- step:
runs-on:
- self.hosted
- test
- linux.shell
script:
- docker version
i got thin result
"Cannot connect to the Docker daemon at tcp://localhost:2375. Is the docker daemon running?"
I have Docker installed, docker.service and docker.socket is active on runner.
Theodora Boudale
November 1, 2022
Hi @Ievgen Koshevyi and welcome to the community!
Docker has not been tested and is not supported for Linux Shell Runners. That being said, I think the issue is that we are setting the variable DOCKER_HOST to tcp://localhost:2375 which leads to issues.
In order to work around this, you can add the command export DOCKER_HOST="" in your script as follows:
pipelines:
branches:
master:
- step:
runs-on:
- self.hosted
- test
- linux.shell
script:
- export DOCKER_HOST=""
- docker version
Please feel free to let me know if that solves the issue and if you have any questions.
Theodora
Ievgen Koshevyi
November 1, 2022
Yeah. It works. Thank you!
Like • 3 people like this
