How to write a bitbucket-ppipeline.yml for django+react app for deployment to heroku
Praveen Yadav
January 26, 2021 edited
I am getting error when I am using these pipeline steps..
Heroku is detecting only python buildpack not reactjs
pipelines:
default:
- step:
image: python:3.8.5
script:
- cd backend
- git archive --format=tar.gz master -o sample-app.tar.gz
artifacts:
- backend/sample-app.tar.gz
- step:
name: Build and Test for react
image: node:10.19.0
trigger: manual
caches:
- node
script:
# Use a in-memory sqlite3 database
- export TRAMPOLINE_CI=true
- cd frontend
- rm -rf package-lock.json
- rm -rf node_modules
- npm install
- npm run build
- step:
name: Deploy to production
deployment: production
trigger: manual
caches:
- pip
- node
script:
- pipe: atlassian/heroku-deploy:1.2.1
variables:
HEROKU_API_KEY: $HEROKU_API_KEY
HEROKU_APP_NAME: $HEROKU_APP_NAME
ZIP_FILE: backend/sample-app.tar.gz
seanaty
January 27, 2021
Please post the error.
Praveen Yadav
January 30, 2021 edited
I am getting this activity-logs on Heroku.
 my files structure is:
/backend
       /backend
       /myapp
      /media
      -manage.py
      -db.sqlite3
      -runtime.txt
      -requirements.txt
/frontend
      /src
      /node_modules
      -index.html
      -package.json
      -package-lock.json
-Procfile
-bitbucket-pipelines.yml
-----> Building on the Heroku-20 stack
-----> App not compatible with buildpack: https://buildpack-registry.s3.amazonaws.com/buildpacks/heroku/nodejs.tgz
 !     ERROR: Application not supported by 'heroku/nodejs' buildpack
 !     The 'heroku/nodejs' buildpack is set on this application, but was
 !     unable to detect a Node.js codebase.
 !     A Node.js app on Heroku requires a 'package.json' at the root of
 !     the directory structure.
 !     If you are trying to deploy a Node.js application, ensure that this
 !     file is present at the top level directory. This directory has the
 !     following files:
 !     backend/
 !     myapp/
 !     db.sqlite3
 !     manage.py
 !     media/
 !     If you are trying to deploy an application written in another
 !     language, you need to change the list of buildpacks set on your
 !     Heroku app using the 'heroku buildpacks' command.
 !     For more information, refer to the following documentation:
 !     https://devcenter.heroku.com/articles/buildpacks
 !     https://devcenter.heroku.com/articles/nodejs-support#activation
       More info: https://devcenter.heroku.com/articles/buildpacks#detection-failure
 !     Push failed
