×Im using bitbucket v 7.21 and used webhook url for https . But test connection dont work.
It works for http connection. Is there any option to skip ssl while using https. Please assist.
The HTTPS protocol uses SSL (generally people talk about TLS these days). You wouldn't be able to turn it off and still be using https. It sounds like you already can make it work with HTTP. Do you have details on what you mean by "skip ssl" other than that?
