I am configuring webhooks in Bitbucket Server 6.1, to automate post-commit code pushes to repositories on 2 Windows-based servers. Some webhooks worked immediately, some worked intermittently, and some failed with the error "javax.net.ssl.SSLHandshakeException: General SSLEngine problem". The failures are not specific to one server or the other, just specific repositories on either server.
This makes no sense to me, as I would expect multiple webhooks to the same server to either all work or all fail. I have read about the cross importation of SSL certificates, to make sure that BbS and a target server properly recognize each other. However, I do not know if this is relevant to my specific situation, per my webhook description, above.
Consequently, I need some specific, detailed instructions on how to create reliable webhook connections between BbS, running on a Windows 2012 r2 server, and repositories on 2 Windows 2019 servers. IIS 10 is being used on the two Windows 2019 servers.
Any assistance would be greatly appreciated.
TIA,
Scott
Alternatively, would I be able to achieve the same result by using the Mirror hook?
I tried adding a mirror hook, but that is not moving committed code on to the next repository.
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨Online forums and learning are now in one easy-to-use experience.
