Implementing CI/CD pipeline in bitbucket
Rohit Pundlik December 17, 2019
I am trying to implement CI/CD pipeline in bitbucket for the project. Basically whenever new code will pushed to the branch 'XamDev', I want to deploy the web api on aws elastic beanstalk using bitbucket CI/CD.
Below is the bitbucket-pipelines.yml for the same where I have configured all aws settings. This file I have added in Visual studio solution.
# This is a sample build configuration for .NET Core.
# Check our guides at https://confluence.atlassian.com/x/5Q4SMw for more examples.
# Only use spaces to indent your .yml configuration.
# You can specify a custom docker image from Docker Hub as your build environment.
image: microsoft/dotnet:sdk
pipelines:
  default:
    script:
          - echo "This script runs on all branches that don't have any specific pipeline assigned in 'branches'."
  branches:
    XamDev:
    - step:
        caches:
          - dotnetcore
        script: # Modify the comma`nds below to build your repository.
          - pipe: atlassian/aws-elasticbeanstalk-deploy:0.5.4
            variables:
              AWS_ACCESS_KEY_ID: '<Access_Key>'
              AWS_SECRET_ACCESS_KEY: '<Secret_Key>'
              AWS_DEFAULT_REGION: 'us-east-1'
              APPLICATION_NAME: '<ApplicationName>' // elastic beanstalk application name provided
              ENVIRONMENT_NAME: '<EnvironmentName>' // elastic beanstalk environment provided
              ZIP_FILE: 'myfile.zip'
              # S3_BUCKET: '<string>' # Optional.
              # VERSION_LABEL: '<string>' # Optional.
              # DESCRIPTION: '<string>' # Optional.
              # WAIT: '<boolean>' # Optional.
              # WAIT_INTERVAL: '<integer>' # Optional.
              # COMMAND: '<string>' # Optional.
              # DEBUG: '<boolean>' # Optional.
So, after committing the code, I am not seeing any pipeline is running from bitbucket nor the aws deployment using elastic beanstalk is started.
When I checked my bitbucket account and branch it doesn't show any pipeline is configured. I am using VS 2019 with .net core web api.
Any help on this appreciated !
Oleksandr Kyrdan
January 16, 2020 edited
Hi @Rohit Pundlik ,
Thank you for your feedback!
Have you enabled Bitbucket Pipelines for you repository?
Also you can follow Deploy to AWS with Elastic Beanstalk guide.
Alex
Rohit Pundlik January 19, 2020
Hi @Oleksandr Kyrdan
Yes, I have already enabled the Pipelines, that is the reason I can seen the pipeline has any errors OR not.
Also, I am already following the link which you have mentioned in the reply.
Still, I am not able to get this done.
Can you tell me exactly where I am doing wrong ?
Rohit
Oleksandr Kyrdan
January 23, 2020
@Rohit Pundlik
looks like you missed 'step' in your default pipeline.
You can validate your pipeline file in the Validator for bitbucket-pipelines.yml.
More details you can find in the guide Configure bitbucket-pipelines.yml.
Structure should be:
Rohit Pundlik February 28, 2020
Thanks for the answer.
Now, I have almost configuration errors , but only the thing is its not getting deployed on aws elastic beanstalk.
So I have open a new thread, can you please give some solution on this?
https://community.atlassian.com/t5/Bitbucket-Pipelines-questions/Bitbucket-CI-CD-Pipeline-with-aws-elastic-beanstalk/qaq-p/1313053#M2099
Thanks for the help !
Rohit
