×I'm trying to evaluate Stash, specifically with an end goal of migrating from a very legacy SVN setup as well. I'm new to this team, and was not involved in the inital SVN layout. Anyway, long story short, its a mess. I've used svn2git, and the rather generic Atlassian docs, but, well, GIGO, I suppose. I see that pull requests can go across repositories (and assume, automatic triggers could, too). Maybe I just need to build things out by hand.
I guess, I'm wondering if there is a more full "worst case" import scenario?
In Stash once you create a repository there is a "Import from SVN" link on the new repository page. This will import directly from Subversion. I have used this with much greater success then any of the svn2git or other conversion options to import non tradional type SVN repositories into Git. (Repo's exceeding 1.5 GB per branch in SVN) As far as process goes if moving to Git you should be starting to look at your processes in a whole new way as well....
Good suggestion Andrew. FYI that's not in Stash by default - you need to install the following plugin:
Sorry, I thought you're already using our plugin for Stash.
Just install SVN Mirror Add-on, create new Git repository and click "SVN Mirror" button on repository page. Then, on SVN settings page, specify the options I've listed in my previous comment:
trunk = plugins:refs/heads/master
branches = somethingelse:refs/heads/somethingelse; differentthing:refs/heads/differentthing; branches/*:refs/heads/*; branches/client_ABC/*:refs/heads/client_ABC/*; branches/client_FOO/*:refs/heads/client_FOO/*
tags = tags/plugins/*:refs/tags/plugins/*; tags/client_ABC/*:refs/tags/client_ABC/*; tags/client_FOO:refs/tags/client_FOO
Alternatively, you can use SubGit 2.0:
$ subgit configure --svn-url $SVN_URL $GIT_REPO
Then adjust $GIT_REPO/subgit/config file:
[svn]
branches = differentthing:refs/heads/differentthing
branches = branches/*:refs/heads/*
branches = branches/client_ABC/*:refs/heads/client_ABC/*
branches = branches/client_FOO/*:refs/heads/client_FOO/*
tags = tags/client_ABC/*:refs/tags/client_ABC/*
tags = tags/client_FOO:refs/tags/client_FOO
And finally run import command:
$ subgit import $GIT_REPO
This time import should go much faster as the previous time you've specified invalid configuration that converted certain branches as regular directories which is very time consuming.
Feel free to use a trial license for SVN Mirror Add-on; as to SubGit, one should pay for mirroring functionality only, converting any repository is always free.
Hope that helps,
Semyon
Jeff,
Here're the proper options for your repository layout:
Once you've specified your branches and tags like this, import should work well. In case you have any other questions please contact us at support at subgit.com or via our issue tracker
Regards, Semyon
I haven't seen git filter-branch; I should have explicitly mentioned I'm not familier with Git (or DVCS) generally. Maybe that is what I need.
Yesterday was spent redoing the import with SubGit (very slow SVN server). Granting that was fewer steps than svn2git, past testing/eval, it might be a one time thing so no sale).
As for "complex", for example, the layout is (trimmed)
/ /somethingelse /differetntthing /plugins (actually "trunk") /tags/plugins/3.1.0 /tags/plugins/3.1.2 /tags/client_ABC/3.1.0 /tags/client_ABC/3.1.2 /tags/client_ABC/3.2.0 /tags/client_FOO/3.1.0 /tags/client_FOO/3.1.2 /tags/client_FOO/3.2.0 /branches/plugins /branches/client_ABC/3.2-maint
(etc, etc)
With the defaults, (save renaming trunk), the subgit created repos looka something like:
(branches)
heads/client_ABC
heads/client_FOO
master
client
(tags)
tags/client_ABC
tags/client_FOO
tags/plugins
and then, under (tags) tags/client_ABC is a directory: /3.1.2
I would have expected to see, in the drop down under tags something like
or even
tags/client_ABC_3.1.2
Presumably, git-filter-branch could deal with this type of chicancery. I guess that is my question then, is are their some examples around of end-to-end SVN->git/stash migration where the SVN layout isn't exactly sane, starting out.
FWIW, I'm not personally sure the current workflow flow ("thats the real WTF"). I'm presuming something like:
/branches/client_ABC/3.2-maint --> /tags/client_ABC/3.2.1
--> /branches/plugins/
--> /plugins
Hi Jeff,
I'm not quite sure what you're asking?
Just a few things:
1. Have you seen git filter-branch? It's pretty much the swiss army knife of repository manipulation, don't leave home without it. You could, for example, extract sub repos from your single SVN repo. Or even move folders (and history) from one place to another. And much more. Not sure if that's helpful?
2. I haven't used svn2git, generally git-svn is awesome except for speed. If you're history is missing something that's where I would start.
3. Not sure what you mean by PRs across repositories? We only allow users to create PRs across one repository and any child forks. By automatic triggers do you mean hooks? Hooks are generally enabled and configured per repository.
4. What do you mean full 'worst case' import scenario?
Apologies that I've not quite understood your question.
Charles
