I'm using Windows 7. At step 7 of the installation instructions I have run bin\start-stash.bat but when going to http://localhost:7990 I get the message "impossible to connect to localhost:7990.
Any help is appreciated.
PS: at step 4 I just installed Git by following the instructions, I DIDN'T install Perl.
Hi, do you have Windows firewall enabled? Have you opened up the Firewall for that port/application? Usually a popup does appear asking you to unlock it.
Hi Stefano,
Could you please raise a support issue at https://support.atlassian.com/. Our support engineers will need to have a look at your log files in order to help you with this problem.
Tom
Learn more
