I am working on a plugin for Bitbucket and IntelliJ isn't importing the dependencies. For Example:
import com.atlassian.bitbucket.commit.CommitRequest;
"bitbucket" is marked red. I imported the project as a Maven project and enabled the automatic import option.
My Pom looks like this:
<?xml version="1.0" encoding="UTF-8"?>
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/maven-v4_0_0.xsd">
<modelVersion>4.0.0</modelVersion>
<groupId>com.zuehlke.ams.pss</groupId>
<artifactId>monitor.bitbucket</artifactId>
<version>1.0.0-SNAPSHOT</version>
<organization>
<name>Example Company</name>
<url>http://www.example.com/</url>
</organization>
<name>monitor.bitbucket</name>
<description>This is the com.zuehlke.ams.pss:monitor.bitbucket plugin for Atlassian Bitbucket Server.</description>
<packaging>atlassian-plugin</packaging>
<dependencyManagement>
<dependencies>
<dependency>
<groupId>com.atlassian.bitbucket.server</groupId>
<artifactId>bitbucket-parent</artifactId>
<version>${bitbucket.version}</version>
<type>pom</type>
<scope>import</scope>
</dependency>
</dependencies>
</dependencyManagement>
<dependencies>
<dependency>
<groupId>com.atlassian.sal</groupId>
<artifactId>sal-api</artifactId>
<scope>provided</scope>
</dependency>
<dependency>
<artifactId>bitbucket-api</artifactId>
</dependency>
<dependency>
<artifactId>bitbucket-spi</artifactId>
</dependency>
<dependency>
<artifactId>bitbucket-page-objects</artifactId>
</dependency>
<dependency>
<groupId>javax.servlet</groupId>
<artifactId>javax.servlet-api</artifactId>
</dependency>
<dependency>
<groupId>junit</groupId>
<artifactId>junit</artifactId>
<version>4.10</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>commons-lang</groupId>
<artifactId>commons-lang</artifactId>
<version>2.6</version>
</dependency>
<dependency>
<groupId>com.atlassian.plugin</groupId>
<artifactId>atlassian-spring-scanner-annotation</artifactId>
<version>${atlassian.spring.scanner.version}</version>
<scope>compile</scope>
</dependency>
<dependency>
<artifactId>atlassian-spring-scanner-runtime</artifactId>
<scope>runtime</scope>
</dependency>
<dependency>
<groupId>javax.inject</groupId>
<artifactId>javax.inject</artifactId>
<version>1</version>
</dependency>
<!-- WIRED TEST RUNNER DEPENDENCIES -->
<dependency>
<groupId>com.atlassian.plugins</groupId>
<artifactId>atlassian-plugins-osgi-testrunner</artifactId>
<version>${plugin.testrunner.version}</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>javax.ws.rs</groupId>
<artifactId>jsr311-api</artifactId>
<version>1.1.1</version>
</dependency>
(couldn't post the whole Pom, but it's almost like the default one)
If I do atlas-run it works just fine and I can use the Plugin. So why isn't intellij downloading the dependencies?
