Is it possible to use variables in the artifacts section of a step in the pipelines.yml file?
Steve Maxwell
April 16, 2020
We have a custom pipeline with a "Project" variable defined.   Using the variable works fine in the script section, but doesn't appear to work in the artifacts section.
- step: build-test-apprevision
name: Build, Test, Create App Revision
script:
- bash ./gradlew :$Project:createAppRevision
artifacts:
- $Project/build/artifacts/$Project-apprevision
Am i doing something wrong or is this not possible?
Andrew Hill
June 11, 2024
bitbucket suggests, in a completely non-patronising way, the use of premium dynamic pipelines to solve this
BCLOUD-21666
"We're extremely excited to announce the GA release of a really powerful feature in Bitbucket Pipelines called Dynamic Pipelines. ......
One of the MANY things Dynamic Pipelines solves is the ability to inject variables into things like artefacts etc."
Ruggero Schirinzi
June 8, 2023
following @Felipe Jaekel  issue, the only way I found to handle this behavior is to specify into the artifacts section something like "*.json" and then to recalculate the filename in each following steps. It is tricky and clunky but it could works.
david_treblig
November 16, 2022
I just found this and we have the same issue. The env variables seem to be parsed in many other sections of the bitbucket-pipeline such as condition.changesets.includePaths, but not in artifacts...
Fotis Papadamis
January 17, 2023
Tried to work with repository variables in condition.changesets.includePaths and it does not seem to work. Same thing with artifacts, of course.
It's really sad...
Felipe Jaekel
February 7, 2022
Marvin Kraner
December 14, 2020
I encountered the same problem. I need to add a time-stamp to the artifacts name and it seems that variable references are not working in the "artifacts"-section. It would be good to know wether we are doing something wrong or if this feature will be added in near future.
Upcoming Bitbucket Events
