Need Company names providing solution for migrating svn to git.
Hi Pradeep,
If you're using Bitbucket Server for hosting your Git repositories, then SVN Mirror add-on for Bitbucket is the best way to migrate your SVN projects:
In case you're not going to use Bitbucket Server, take a look at SubGit which is command-line tool (SVN Mirror add-on relies on SubGit to provide import and mirror functionality).
Semyon
Hi Pradeep,
In addition to Jobin's comment, in case you're also interested in checking at steps to perform the migration yourself, you may refer to https://www.atlassian.com/git/tutorials/migrating-overview/ which is a guide step-by-step to perform the migration.
Gustavo Refosco
