I want to connect in a external postgresql database and i have this message.
The configuration entered is not valid. A database connection could not be established. Please check your configuration and try again. com.atlassian.stash.internal.db.DefaultDatabaseManager.validateConfiguration(DefaultDatabaseManager.java:217) com.atlassian.stash.internal.db.DefaultDatabaseManager.prepareDatabase(DefaultDatabaseManager.java:183) com.atlassian.stash.internal.maintenance.SpringMaintenanceTaskFactory.setupTask(SpringMaintenanceTaskFactory.java:159) ... Could not get JDBC Connection; nested exception is org.postgresql.util.PSQLException: Connection attempt timed out. org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:80) com.atlassian.stash.internal.db.DefaultDatabaseValidator.validate(DefaultDatabaseValidator.java:44) com.atlassian.stash.internal.db.DefaultDatabaseManager.validateConfiguration(DefaultDatabaseManager.java:214) ... Connection attempt timed out. org.postgresql.Driver$ConnectThread.getResult(Driver.java:368) org.postgresql.Driver.connect(Driver.java:279) java.sql.DriverManager.getConnection(DriverManager.java:664) ...
Thank you!!
It looks like the server where you have installed Bitbucket Server is unable to reach the external DB. I would start by checking the network and firewall settings.
Hello Jobin,
Good answer!!!
Actuely, i want to clone projet in stash to bibucket server and i have this error.
Best regards;
Sorry, can you translate that to English for me?
Not sure what the issue is. You can check the logs, as mentioned in the error, and hopefully that will give you more details on why this is happening.
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
