JAVA_HOME is not set and no 'java' command could be found in your PATH. bitbucket pipeline
Mahmoud August 30, 2018
Hi i tried to exxecute a gradle command in bitbucket pipeline
definitions:
services:
java:
image: openjdk:8
pipelines:
default:
- step:
name: Build And Test
services:
- java
script:
- bash ./gradlew clean build
- bash ./gradlew test
- step:
deployment: test
image: google/cloud-sdk:214.0.0-alpine
services:
- java
- docker
caches:
- gradle
script:
- gcloud auth configure-docker --quiet
- docker login -u _json_key -p "$GCR_JSON_KEY" https://gcr.io
- bash ./gradlew bake -Penv=test -PisRelease=false --info --stacktrace
when it tried to execute the latest task
 it give the error
what is the issue in this case?
Graham Gatus
August 30, 2018
Hi @Mahmoud
I can see you've attempted to add the 'openjdk:8' docker image as a service. Services are designed to provide additional databases, webservices etc as part of your build, and not provide CLI tools (the exception is the pipelines built in 'docker' service, which in addition to providing a docker daemon, also makes the docker CLI available by mounting in a volume containing the docker CLI  - see https://confluence.atlassian.com/bitbucket/run-docker-commands-in-bitbucket-pipelines-879254331.html).
The pipelines default image already provides Java 1.8.0_151, so if you want to continue using this, you can re-write your first step to be:
    - step:
script:
In your second step, you will need to either:
- Use a custom docker image that has both gcloud tools and the jdk, or
- Use the default pipelines image, and install the gcloud CLI manually
The following is an example step which has docker as a service, jdk and gcloud CLI, where the google cloud CLI is installed as part of the build:
step:
services:
docker
nameBuild And Test
script:
# Install gcloud CLI
export CLOUD_SDK_REPO="cloud-sdk-$(lsb_release -c -s)"
echo "deb http://packages.cloud.google.com/apt $CLOUD_SDK_REPO main" | sudo tee -a /etc/apt/sources.list.d/google-cloud-sdk.list
curl https://packages.cloud.google.com/apt/doc/apt-key.gpg | sudo apt-key add -
sudo apt-get update && sudo apt-get install -y google-cloud-sdk
gcloud --version
java -version
docker --version
Instructions for installing the gcloud CLI can be found at https://cloud.google.com/sdk/docs/downloads-apt-get
Cheers
Graham
Mahmoud September 2, 2018
Thanks @Graham Gatus for clarifying this to me. I've took the second option and it works now, Many thanks :)
Like Mohd Farid Mansoori likes this
Jerry Buaba
November 30, 2019
this worked
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
