Java project with ant. Can i use for builda dn deployment to my server?
CCI_SINGHNI
December 2, 2018
I have a Java project with ANT build. I want to use Bitbucket pipelines for build, deployment. Can you please share the steps for executing it?
Philip Hodder
December 3, 2018
Hi Nitin,
Bitbucket Pipelines provides a bash shell that you can execute builds in. You'll need to ensure that Ant is installed in the Docker image you use.
The default Pipelines Docker image already has Ant installed.
What ant commands are you running locally? You should be able to reuse the same commands in the script section.
Here's an example:
image: atlassian/default-image:2
pipelines:
default:
- step:
script: # Place the commands you normally run locally into this section.
- ant
Phil
CamilaSalles
October 31, 2019
Hello Philip,
When you say
is just put the originals commands with original indentation ? Because I put what you said and appears several errors and don't work.
Could you give a example with some lines of xml of command ant build?
Thank you,
Ample Admin April 19, 2021
We are facing same issue did you solved this issue?
Shoaib Khan June 29, 2021
After the build is done what is the default location of the .war/.jar file?
Can we define it here?
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
