×Not sure if this is the correct forum to ask this question but the Jenkins Stashnotifier plugin does not support multiple git scm configuration. We have many build projects that clone several git repositories but the notifier only updates the first repo's commit with the jenkins build information/status.
Will the plugin be updated to support multi git SCM configuration? I see an issue on github, https://github.com/jenkinsci/stashnotifier-plugin/issues/15, from 4 months ago but i don't see if there is any status on this.
Thanks in advance!
Jennifer
Hi Jennifer,
Your best bet is on that Github ticket. I've just had a quick look at the code, and should be trivial if you can get access to the multiple SHAs that were built.
This may work, but I haven't had a chance to test it (EDIT: Whoops, didn't add them to the list):
https://github.com/charleso/stashnotifier-plugin/commits/bugfix/15-multiple-repos
Charles
Charles, any chance you could submit a pull request for this? We need this enhancement, as well as some of the more recent other stash-notifier enhancements to support our environment. Thanks.
