Hi Folks,
We have now configured a whole host of Pipeline Steps using BB, and now I would like to integrate our Robot framework Tests for Regression testing. Although it is technically possible to do this via the Provided Bitbucket Pipelines, I need to solve a few issues:
1. Often the regression test will take in excess of 120mins, in this case Bitbucket will Fail the step
2. The long-running process consumes Build Minutes at a rate greater than my Coffee consumption.
My initial working theory, was to offload the Testing to an EC2 Instance, and initiate the Run using the ssh-run pipe.
The trouble with this, is that the pipe will wait until execution has completed (See Point 1 & 2)
So, how can I initiate execute a script on a remote host, pause / stop the pipeline, update the status later once complete without consuming unnecessary build minutes or exceeding the time limit.
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨Online forums and learning are now in one easy-to-use experience.
