Malicious repository
Anthony Bautista
September 29, 2025
I was reached out to by a "recruiter" on LinkedIn who asked me to perform a task to show competency.
I ran some of the code through ChatGPT and found a malicious backdoor.
The malicious code is here: https://bitbucket.org/screening_assessment/mike_dex_challenge/src/main/server/controllers/orderController.js
GPT says:
  • exports.getCookie ... )(); is immediately invoked at module load (IIFE), so it runs as soon as the controller is required.
  • It fetches remote data from api.mocki.io/... and passes res.data.cookie straight into errorHandler.
  • errorHandler uses new (Function.constructor)('require', errCode) and then executes it with handlerFunc(require).
    That is equivalent to new Function('require', '<REMOTE CODE HERE>')(require), i.e. arbitrary code execution with access to Node’s require. This is a classic RCE backdoor / remote loader.
Can someone please remove this repo?
Mikael Sandberg
Hi @Anthony Bautista,
Please reach out to abuse@atlassian.com and that team will investigate. Please note that they will not reach out to you, but they will take action on it.
