I"m installing Bitbucket 5.14 version on Windows 2016 server. While installing the Git client which option I've to choose for HTTPS transport backend?. Is it use the OpenSSL library or use the native Windows Secure Channel library?.
I am going to configure SSL on 443 for Bitbucket server. is there any dependency on Git client HTTPS transport backend method while configuring SSL for Bitbucket?. If I use native Windows Secure channel library, do I need to upload the bitbucket SSL certificates to Windows certificate store?
Hi Ramana,
OpenSSL library is typically what is used on linux installations though there isn't necessarily a recommendation on which to use. When it comes to using SSL certificates, you will need to ensure that the system and server are trusting each-other or rather that git is trusting connections from your Bitbucket URL and vice versa.
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨Online forums and learning are now in one easy-to-use experience.
