file_path: /opt/atlassian/pipelines/agent/helpie/features/kb/access-control/access-control.php
Fatal error: Uncaught Error: Class 'Helpie\Features\Kb\Access_Control\Access_Control' not found in /opt/atlassian/pipelines/agent/build/helpie.php on line 120Error: Class 'Helpie\Features\Kb\Access_Control\Access_Control' not found in /opt/atlassian/pipelines/agent/build/helpie.php on line 120
As you see, that's the file_path generated by my auto_loading which is correct but the class is not being called.
This works in my local dev setup.
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨Online forums and learning are now in one easy-to-use experience.
