Pipeline Tags globing pattern
ismael-h May 4, 2017
Hi all,
I am currently trying to trigger application deployment on tag.
Everything is ok when I follow the pattern "foo-*" .
However I'd like to follow semversioning on my app (1.2.3-beta).
So I put the following pattern:
+([0-9]).+([0-9]).+([0-9])-beta*
Doing so, the trigger does not work.
Am I missing something.
Does the pattern matching depends on the image we specify in the yml ?
Here is the complete section of the yml.
tags:  # {staging, stable, prod} environments deployment are triggered on tag only
    +([0-9]).+([0-9]).+([0-9])-beta*:
      - step:
          script:
          - mvn -B -s settings.xml clean install -P staging
          - cd endpoints-api
          - echo ${GOOGLE_CLIENT_SECRET} > client-secret.json
          - gcloud auth activate-service-account --key-file client-secret.json
          - version=$(echo ${BITBUCKET_TAG} | tr . -)
          - mvn -B -s ../settings.xml appengine:deploy -Dapp.deploy.version=$version -P staging
    +([0-9]).+([0-9]).+([0-9])-rc*:
      - step:
          script:
          - mvn -B -s settings.xml clean install -P prod
          - cd endpoints-api
          - mvn -B -s ../settings.xml appengine:deploy -Dapp.deploy.version=$version -P prod -Dservice_name=stable -Dtemplate_file_id=1Kiv3stWFWsoCBnRFWfIfZ2VUNTk__12n9vevQF4AtPk
    +([0-9]).+([0-9]).+([0-9]):
      - step:
          script:
          - cd endpoints-api
Note, I replace the . by - because the version name cannot contain '.' in google appengine app.
Thx for your help.
SebC
May 22, 2017 edited
There's no regex support for tags/branches, it's all simple globs - see https://confluence.atlassian.com/bitbucket/configure-bitbucket-pipelines-yml-792298910.html#Configurebitbucket-pipelines.yml-globbing_patternsGlobpatternscheatsheet for examples.
what would happen if you followed the patterns?:
*-beta*:
*-rc*:
default:
ismael-h November 9, 2017
It's what iI finally did.
Rui Gazio
October 20, 2021
Examples are good but how about the spec? Does it support "?", "extglob" patterns as  bash does?
Nick Reilingh
December 21, 2022
You can do `shopt -s extglob` in a single script step -- this will affect subsequent script lines and allow you to use extglob.
atlassian, confluence administration certification, atlassian certified professional, confluence admin for cloud, atlassian learning, confluence training, confluence certification exam, confluence cloud admin, admin credential, atlassian certification
Become a certified Confluence admin today! 📖
Stand out as a skilled Confluence Cloud administrator. The Confluence Administration for Cloud certification proves you can configure permissions, manage site and space settings, and monitor activity—ensuring secure, effective collaboration for your team.
