Pipeline maven build fails but is succesfull locally
Harsha Vardhan
Error that I am getting Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile
MY POM.xml
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
<modelVersion>4.0.0</modelVersion>
<groupId>WebDriverTest</groupId>
<artifactId>WebDriverTest</artifactId>
<version>0.0.1-SNAPSHOT</version>
<dependencies>
<dependency>
<groupId>junit</groupId>
<artifactId>junit</artifactId>
<version>3.8.1</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>org.seleniumhq.selenium</groupId>
<artifactId>selenium-java</artifactId>
<version>3.12.0</version>
</dependency>
<dependency>
<groupId>org.testng</groupId>
<artifactId>testng</artifactId>
<version>6.14.3</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>org.apache.poi</groupId>
<artifactId>poi</artifactId>
<version>3.17</version>
</dependency>
<dependency>
<artifactId>poi-ooxml</artifactId>
<version>3.9</version>
</dependency>
<dependency>
<groupId>log4j</groupId>
<artifactId>log4j</artifactId>
<version>1.2.17</version>
</dependency>
<dependency>
<groupId>commons-io</groupId>
<artifactId>commons-io</artifactId>
<version>2.4</version>
</dependency>
<dependency>
<groupId>org.apache.httpcomponents</groupId>
<artifactId>fluent-hc</artifactId>
<version>4.5.5</version>
</dependency>
</dependencies>
<build>
<pluginManagement>
<plugins>
<plugin>
<groupId>org.apache.maven.plugins</groupId>
<artifactId>maven-compiler-plugin</artifactId>
<version>3.7.0</version>
<configuration>
<source>1.7</source>
<target>1.8</target>
</configuration>
</plugin>
</plugins>
</pluginManagement>
<plugins>
<plugin>
<artifactId>maven-surefire-plugin</artifactId>
<version>2.21.0</version>
<configuration>
<includes>
<include>HomePageAssertions.java</include>
<include>UserJourneys.java</include>
</includes>
</configuration>
</plugin>
</plugins>
<defaultGoal>install</defaultGoal>
</build>
</project>
Graham Gatus
March 5, 2019 edited
@Harsha Vardhan are you able to provide some further details regarding your bitbucket-pipeline.yml file, as well as the source, and the output from maven ( if you can reproduce the problem, perhaps create a new public repository and post a link here demonstrating the problem).
A few things you can try to narrow down the possibilities:
- Run maven with the '-e -X' flags to produce more verbose output.
- Compare jvm version locally vs pipelines (java -version)
- Compare maven version locally vs pipelines (mvn -version)
You can also try to build locally using the Bitbucket Pipelines docker image. From within your local project, start up the pipelines build container, and mount in your project as a volume and set that as the working directory:
docker run -v $(pwd):$(pwd) -w $(pwd) -it atlassian/default-image:latest bash
You can then issue the mvn command to try and reproduce the problem.
atlassian, confluence administration certification, atlassian certified professional, confluence admin for cloud, atlassian learning, confluence training, confluence certification exam, confluence cloud admin, admin credential, atlassian certification
Become a certified Confluence admin today! 📖
Stand out as a skilled Confluence Cloud administrator. The Confluence Administration for Cloud certification proves you can configure permissions, manage site and space settings, and monitor activity—ensuring secure, effective collaboration for your team.
