Pipelines System Error when LFS clone enabled: true
jhonsen.djajamuliadi
October 3, 2022 edited
I'm adding a step-level git-lfs clone in bitbucket-pipelines.yml file, as described here, but it throws a System Error during build. The repo I'm working on is a forked repo that had git-lfs configured (it had .gitattributes in the repo).
image: continuumio/anaconda3:latest
pipelines
pull-requests
'**': # runs as default for any branch
- step:
clone:
lfs: true
script:
- if [ -f environment.yml ]; then conda env create -f environment.yml; fi
- git clone --branch="test" git@bitbucket<somerepo>
Error encountered:
- error downloading object (error logs below)
Steps taken to resolve (but failed):
- Removed step-level clone, and specified it globally, but same error encountered
- Added `git lfs install` as part of build step instead of using `clone: enabled: true` but git lfs command is not recognized
+ umask 000
+ git lfs 2>/dev/null >/dev/null || if [ $? -ne 0 ]; then exit 86; fi
+ retry 6 git clone --branch="add_ci_backbone"   $BUILD_DIR
Cloning into '/opt/atlassian/pipelines/agent/build'...
Downloading data/df_clean.csv (15 MB)
Error downloading object: data/df_clean.csv (19f9dde): Smudge error: Error downloading data/df_clean.csv (sha...): [sha...] Object does not exist on the server: [404] Object does not exist on the server
Errors logged to '/opt/atlassian/pipelines/agent/build/.git/lfs/logs/20221003T160918.187587842.log'.
Use `git lfs logs last` to view the log.
error: external filter 'git-lfs filter-process' failed
fatal: data/df_clean.csv: smudge filter lfs failed
warning: Clone succeeded, but checkout failed.
You can inspect what was checked out with 'git status'
and retry with 'git restore --source=HEAD :/'
Attempt 1 of 6 failed.
Retrying in 1 seconds
Attempt 2 of 6 failed.
Retrying in 2 seconds
fatal: destination path '/opt/atlassian/pipelines/agent/build' already exists and is not an empty directory.
Syahrul
October 11, 2022
Hi @jhonsen.djajamuliadi
Welcome to the community!
Based on the log you shared, the clone is failing because it fails to download LFS files:
The remote repository is missing "data/df_clean.csv" files as per the above error.
Can you check if you have these files locally by running the following commands:
Locate the missing files, UUID exists locally:
git lfs ls-files | grep 19f9dde
If the OID exists, push the files back to the remote repository:
git lfs push origin --all
Once pushed, re-run the pipeline build again and let me know if that works.
Syahrul
October 14, 2022
Hi @Syahrul
I appreciate your response! Following up on your suggestion works, I ended up on this current limitations for git lfs with bb page and it helped me understand the issue.
Now it's been resolved. Thank you!
Jhonsen
Like Syahrul likes this
